PS2 controller interface with PIC24FJ256GB110
averafter
Newbie level 3
Malaysia
I faced problem with interfacing ps2 controller to pic24f controller, can anyone help me? Here is the code:
#include "D:\Program\testing.h"
#pin_select SS1OUT=pin_b15 //Pin 44
#pin_select SDI1=pin_d14 //Pin 47
#pin_select SDO1=pin_d15 //Pin 48
#pin_select SCK1OUT=pin_f4 //Pin 49
#use delay(4000000)
#use rs232(baud=9600,xmit=PIN_f3,rcv=PIN_f8,PARITY=N,BITS=8)
void ps2(void);
int8 reverseByte(int8);
#define ps2CMD PIN_D15
#define ps2ATTN PIN_B15
#define ps2DATA PIN_D14
#define ps2CLK PIN_F4
int8 ps2Byte[9];
int8 ps2Status;
void main()
{ setup_wdt(WDT_ON);
setup_timer1(TMR_DISABLED|TMR_DIV_BY_1);
setup_uart(9600);
setup_spi(SPI_MASTER|SPI_H_TO_L|SPI_CLK_DIV_4);
While(true)
Restart:
output_high(Pin_B15);
ps2();
ps2Status = reverseByte(ps2Byte[2]);
if(ps2Status == 0x5A)
restart_wdt();
Output_high(Pin_F0);
delay_ms(1000);
else
goto restart;
void ps2 (void)
output_low(Pin_B15);
delay_us(20);
ps2Byte[0]=spi_read(0x80);
ps2Byte[1]=spi_read(0x42); //get controller ID
ps2Byte[2]=spi_read(0x00); //response from controller
ps2Byte[3]=spi_read(0x00);
ps2Byte[4]=spi_read(0x00);
ps2Byte[5]=spi_read(0x00);
ps2Byte[6]=spi_read(0x00);
ps2Byte[7]=spi_read(0x00);
ps2Byte[8]=spi_read(0x00);
int8 reverseByte(int8 x)
x = (x & 0x0F) << 4 | (x & 0xF0) >> 4;
x = (x & 0x33) << 2 | (x & 0xCC) >> 2;
x = (x & 0x55) << 1 | (x & 0xAA) >> 1;
return(x);
**I use 4M oscillator, output of the command, attention and clock waveforms seems ok, but there was not data send back to me from the ps2 controller.
