proximity card reader
wisely77
Member level 4
Member level 4
proximity card reader schematic
is anyone know how to design a proximity reader without expensive ic or device. please advice. thanks.
wisely77
samples proximity card readers
Because these devices work by mutual inductance, it is always necessary to provide electronic gain. There are several choices. One is to use the grid dip meter method with tuned circuits on the card. The patent has expired on this method and is now free for anyone to use. Another way is to power the card over the inductive coupling and have it transmit back a signal on another loop. The third way is probably patented. It varies the load on the pick up coil which is sensed in the reader coil.
125 khz proximity card reader schematic
I have used a TEMIC Ic Reader. I have schematics and PCB in Protel format. If you want please PM.
proximity reader schematics
Try to see the following chip:
RI-R6C-001A-01 (S6700 Multi-Protocol Transceiver IC)
This is a single chip supplied by texas.
The S6700 Multi Protocol Transceiver IC enables a broad range of 13.56MHz RFID interrogator designs.
This low power consumption device supports portable and fixed reader designs that have tight footprint constraints.
The IC minimizes onboard power requirements and reduces parts count in a final reader product.
With the addition of a micro-processor, crystal, and a few passive components a full functioning reader can be easily developed.
The device supports multiple RF air interfaces as Tag-it, ISO15693-2 and ISO 14443 (Type A) and opens with the direct mode where data can be passed directly through to a transponder further options.
www.be alchive.com
Any sugestion for an european distribuitor (S6700 chip, or similar)?
proxy card reader schematic
One possible solution would be to use the Dallas TINI devices. The website is
**broken link removed** I believe
Z
card reader pickup coil
Do you think that would work for what you want ?
proximity card
The best book on this subject is
RFID Handbook
Klaus Finkenzeller
J. Wiley
1999
It is available used and new. In the next few months a second edition may come out. This book is scientifically based with many equations and graphs. All of the other books I have seen are written at the Popular Electronics hobby magazine level with pretty pictures and no science or engineering content.
If you are willing to have a complex reader, the old Schlage (now Westinghouse Security Electronics) analog card had several tuned LC circuits with printed inductors. The reader was very much like a grid dip meter and read the frequency of the tuned circuits. Each card had a different combination of frequencies.
proximity reader circuit
Anybody can advise where can developers obtain samples for RI-R6C-001A-01 (S6700 Multi-Protocol Transceiver IC) and subsequently purchase them?
TI recently closed down their online store and it is not supported by general TI distri.
proximity card cheapest
Hi Krag,
You can get them at https://www.rfid.co.uk
Anyone knows where I can get the antenna that fits?
Should be able to detect at 50cm distance, with little output power, and the antenna shouldn't be bigger than 5 * 10 cm.
Regards
Adrian
proximity card format
SONMicro (http://www.sonmicro.com) offer the world's cheapest 125KHZ RFID Reader/Writer design.They give all information and schematic free and sell only the FULLY CUSTOMIZABLE programmed PSoC chip.
PSoC (Programmable Syetem on Chip) techology comes with Cypress Microsystems (http://www.cypress.com/psoc).
Because there are few external components and most building blocks are inside the chip , this is the most cost effective design for now.
electronicsclub.cjb.net
transponder reader schematic
joebazoka
please, send me the circuit, where did u get the components? thanks.
tiris type card reader
joebazoka said:
I have used a TEMIC Ic Reader. I have schematics and PCB in P*otel format. If you want please PM.
Por favor me podrias enviar el alchivo del PCB que tienes con TEMIC en formato Protel y si tubieras informacion de como decodificar los transponders.
mi correo es: escobedo35@yahoo.es
saludos
grid dip meter pcb
hi
i hope it is the sample for u!!
thank
buntheun
proximity card reader schematic proximity
i want more information on card reader and if possible full project
proximity card reader project
hhhhhnhhhhhhhh
Added after 38 seconds:
i have no point
