Jun 1, 2018 #1 hyprfrcx Junior Member level 1 Joined Feb 7, 2018 Messages 16 Helped 4 Reputation 8 Reaction score 4 Trophy points 3 Activity points 149 For the EasyHDL language, for Labcenter Electronics Proteus 8. I have the exact same question than this closed unanswered post. https://www.edaboard.com/showthread.php?289111-Help-with-Proteus-EASYHDL-analog-input For the only help available on internet, and in the included help: http://systembus.com/proteus/EasyHDL/Using_EasyHDL_To_Specify_Analogue_Signals.htm For one analog input, one analog output, and a code that "should" be as simple as: *SCRIPT PROGRAM RND { NODE V(I1) NODE V(O1) O1=2*I1 } *ENDSCRIPT I dont find any way to make this work. Of course what i need is to build a more complex relation between some inputs and deliver it into ano output, but for the language itself, this simple expression is impossible inside Proteus. Which is the option for simulating expressions like ? Thanks in advance.
