Proteus + C program debuging
c program debuging
We concentrate on Keil + Proteus 6.7 connection, forget Proteus 6.9 at this moment.
On Proteus Window Toolbar Menu -> DEBUG - set USE REMOTE DEBUG MONITOR, and try again
    Help
how to use monitor 51 in keil uvision2
Thank. I already success :D linked uVision3 + Proteus6.7. :D
But why Proteus6.9 can't VSM uVision3? :cry:
Does anyone know how to Proteus VSM 6.9 SP5 with Keil µVision3 V3?
Thank you.
keil c and proteus 7
i want to know how to debug c souce in proteus
vsmgadi not install
Hello txdx..
I once use the debug feature of proteus with keil. It worke that time. The proteus version was 6.7. now i installed proteus 6.9, this version doesn't support keil debugging....so you have to revert to 6.7 in order to debug with keil.
Hope this helps
Best Regards,
Buts101
proteus tcp/ip stack
i still dont know how to use proteus...
argghhh
uvision2 uninstall
Hi
I am using Proteus 6.9 SP5 with keil uvisoin2. well i have installed VSMGADI from net & its working also but
If u assign any variable as a Global Variable then its not working. proteus going in to indefinate loop so can anyone tell me How to solve this problem
I have mage Remote Debugging in Proteus
I have seleted VSM Simulator in Keil
Added after 1 minutes:
Hey sorry
Above mess was writeen by me &
It was uvision-3 with Proteus 6.9 SP5 . SO please help me for that
I urgently required it.
keil isd51 link
Thank you.
I think there is some compatiblity problem with uVision2 & 3 and Proteus 6.9 SP5.
I also tried but Got error: Target DLL has been cancelled, Debugger aborted !
And
Proteus 7.1 working fine with uVision2, 3 & 3.5
Proteus 6.5 working fine with uVision2 , 3 & 3.5
Don't bother to use Proteus 6.9 SP5 !
use 6.5 or 6.7 or 7.1 instead.
keil uvision3 debugger to proteus
Cracked version proteus 6.9 sp2 does not support this feature of debugging.
use ver 7.1
i can't find VDM51.DLL. u can help me! thanks so much
