manuel1139
Zerocode,
the most schematics I have seen in this thread are ok... however different goals have been met in this schematics - so it depends on your requirement which one you choose.
If you are willing to spent money without spending too much effort I would suggest you go and buy a ICD2.
If you are willing to spend less to none money take one of the schematics/PCBs in this thread and decide on which components you already have available and how your ICD should work (i.e. you must not have the target drivers if your ICP cable is less than 10cm.
Also you don't need the SPI pot for most of the general PICs and if you don't mind about using an external PSU you can also leave out the charge pump to pump the 5VUSB to 12V Vpp.
Last but not least - the software is still missing the first 128 bytes as they have not been made avialable to the public. So there might be issues...
Best Regards,
Manuel
Best Regards,
Manuel
