Project related to telephone
ajaykumar988
Member level 5
I need to design an easy calling card system through which a user can input his password and call.i also need to maintain a database system through which i can keep track of the balance of the user .
The whole system must be a computer based system with either a parallel or serial port interface .
I desperately need help in this .Please help me through web sites,softwares ,circuit ideas or whatsoever means .
thanks in advance
you read the book serial port complete by jan axleson first
you should first choose the programming language and database management technique.
You can refer to the following for serial communication circuit DIY examples,
https://www.beyondlogic.org/
To interact with the user at the other end of the telephone line,
you can use this MT8870 DTMF IC to decode the dial tone.
You can also design a ring detector using a couple of diode and transistors,
Available in the website too.
You can design detector for progress call tone to add-on more functions.
Most importantly, you need a microcontroller to control
all your devices and interface between user and computer.
I strongly recommend PIC from microchip (example PIC16F877a).
It is easy to learn and there are alot of technical support in the internet.
Enjoy your project,
Siong Boon
