HI
I am new to programming Jennic's 5148 and need some assistance.
Can anyone please suggest me some documents which would help me write codes/programs for the micro-controller.
Yes I have the Jennic 5148 module and the connecting cables. All the required hardware components are present.
I have the eclipse development environment, read through the pdf files along with it. Also I have been through the support links for forums but could not find anything substantial to start off my programming for the device.
basically, some sort of index which tells me the available functions in various header files and say a simple program based on the jennic5148 micro-controller.
The programming style, as in initializing device and stopping device, stuff like that would be great if available.
I am not exactly familiar with the jennic controller, but in general, there's a init() function present to set the state of the controller.
Rest, all the functions are specified in the header files along with the parameters they need to be passed as arguments. So just try out with very simple programs to see if you are able to do them. Then build upon that.
Ya, i am sending you some pdf's that will help you programming the jennic 5148:-D
send me your email, i will send you these pdf's. ijazahmad3605@yahoo.com
i'm a newbie in programming with jennic 5148
i have a MCU.
i have some problems in getting started with jn5148
I would like to know how to get started with these devices, code examples, how to compile using Eclipse and add the required libraries, how to make a PCB for it.
I would really appreciate your help as well.
Thank you very much in advance
