i want a programmer and programming software to burn hex file in atmega32. i am using vistax64 OS. I dont have parallel port but i have usb to serial converter.
please help me......[/b]
The USB to serial converter can be used with Ponyprog: ... but i heard from many people that using a converter the chip programming is very slow compared to a serial port, depends also on the converter chip.
"Keeprog" an USB programmer for AVR devices from United7 technologies is available for just 500 Rupees. Have more details from this link below. Good luck www.united77.com/keeprog.htm
The serial programmer from www.lancos.com which can be used with Ponyprog will not run by a usb-serial converter as these programmers do not use the standard RS232 protocol. To program a AVR its better to go for a usb programmer. The cheapest and most reliable solution. You can find one from shop.extremeelectronics.co.in for about rs 350/- note: Be sure to check compatibility with vista 64 bit..cheerz
I use the TOP2005 programmer which uses the USB port directly and can program almost all the AVRs, plus many other chips, like the PIC microcontrollers and others.
Hope this helped.
Tahmid.
Hope this helped.
Tahmid.
