programmer for AT89S52 needed
7rots51
ponyprog at89s52
hi
I need a programmer for AT89s51(sch ,software).
thanks
at89s52 programer
TO dainis:
PONYPROG DOES NOT SUPPORT AT89S52!
ponyprog at89s
you can use a Willem programer with an adaptor for AT89Cxx. It works fine and it is not expensive!
programer for at89s52
Hi all,
try AEC Electronics. It can program AT89S51/52/53 and AT89S8252 micros via parallel port and very simple to build, using only few resistors.
www.aec-electronics.co.uz
Cheers,
boyzplus
at89s52 programmer
boyzplus said:
Hi all,
Cheers,
boyzplus
Right link is:
diy at89s52 board
hello
Does AEC Electronics DOS software work in win xp or win2000 command prompt?
It is better to have a windows software for this,is there any?
Regards
at89s52 willem
7rots51 said:
hello
For direct I/O port access look DlPortIo
Or GiveIO:
For WinXP also try (?!?) set compatible mode for programm shortcut.
at89s53 instead at89s52
maziar said:
can upload software ?
What software ?
DirectIO, GiveIO, get download links from my previous post ....
at89s52 parallel programmer
Other programmer:
Try SmartPro S51
If you are looking for USB programmer for 89S51 then try SmartPro S51. It supports some other variants as well as SPi Eeprom chips.
Cheers
ceck out the programmer at my home page
"http://sites.google.com/site/rohittkhanna/usbavrprogrammer"
this is a modified version of USBASP and can program AT89Sxx chips!!!
or if your PC has a parallel port use this programmer
Asimov
LaTeX Commands Quick-Menu:
