urja
Newbie level 5
Hi!
I have worked with a DE10-NANO, modifying the MSEL and creating a .jic file, based on a .sof, I managed to load the .jic file into the FPGA. This file enabled that when turning off the FPGA the programmed file would not be erased, and when turning it on again the program began to work by itself.
Now I have started working with an ENCLUSTRA Mercury PE1 + Mercury SA2 (Cyclone V 5CSTFD6F31I7N) and I would like to do the same. I am using Quartus Design Software. In this case I don't have the MSEL pins as accessible as on the DE10-NANO. I have tried modifying the CFG A and CFG B switches, but have not succeeded.
I would like you to help me solve this problem, and to be able to program my FPGA.
That's what I tried to it. I tried to change MSEL, changing BOOT_MODE0 and BOOT_MODE1 with CFG switches. Cyclone V needs MSEL[4..0] = “10010” configuration, but I can't set it only changing CFG switches.
--- Updated ---
