abidr
Full Member level 5
- Joined
- Feb 14, 2007
- Messages
- 255
- Helped
- 37
- Reputation
- 74
- Reaction score
- 32
- Trophy points
- 1,308
- Location
- 33 N, 73 E
- Activity points
- 2,691
Recently, my son was making a project off the net, he found this code and wanted me to help him PORT the code to PIC16F877A, he is using XC8.
The code was originally for PIC18F2620, I have tried to compile the code in XC8 and I keep ending with "failed attempts", this is what I keep getting, can someone point me as to what I am missing:
and this is the code
../RTC.c:60: warning: (361) function declared implicit int
../RTC.c:60: error: (192) undefined identifier "MASTER"
../RTC.c:60: error: (192) undefined identifier "SLEW_OFF"
../RTC.c:64: warning: (361) function declared implicit int
../RTC.c:65: warning: (361) function declared implicit int
../RTC.c:68: warning: (361) function declared implicit int
../RTC.c:69: warning: (361) function declared implicit int
../RTC.c:225: warning: (361) function declared implicit int
../RTC.c:229: warning: (361) function declared implicit int
../RTC.c:231: warning: (361) function declared implicit int
../RTC.c:235: warning: (361) function declared implicit int
../RTC.c:237: warning: (361) function declared implicit int
../RTC.c:284: warning: (361) function declared implicit int
../RTC.c:284: error: (192) undefined identifier "FOUR_BIT"
../RTC.c:284: error: (192) undefined identifier "LINES_5X7"
../RTC.c:285: warning: (361) function declared implicit int
../RTC.c:286: warning: (361) function declared implicit int
../RTC.c:305: warning: (361) function declared implicit int
../RTC.c:309: warning: (361) function declared implicit int
* File: RTC.c
* Author: Student Companion SA: www.studentcompanion.co.za
* Real Time Clock Using DS1307 on I2C Bus
* To simulate in Proteus, The I2C debugger must be connected on the I2C Bus.
//#include "RTC.h"
#define _XTAL_FREQ 8000000
// CONFIG
#pragma config FOSC = HS // Oscillator Selection bits (HS oscillator)
#pragma config WDTE = OFF // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOREN = OFF // Brown-out Reset Enable bit (BOR disabled)
#pragma config LVP = OFF // Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit (RB3 is digital I/O, HV on MCLR must be used for programming)
#pragma config CPD = OFF // Data EEPROM Memory Code Protection bit (Data EEPROM code protection off)
#pragma config WRT = OFF // Flash Program Memory Write Enable bits (Write protection off; all program memory may be written to by EECON control)
#pragma config CP = OFF // Flash Program Memory Code Protection bit (Code protection off)
// PIC16F877A Config Bits
#include <stdio.h>
#include <xc.h>
#include <stdlib.h>
#include <delays.h>
#define MSB(x) ((x>>4)+ '0') //Display Most Significant Bit of BCD number
#define LSB(x) ((x & 0x0F) + '0') //Display Least Significant Bit of BCD number
void DelayFor18TCY(void); //Delay for 18 cycles.
void DelayPORXLCD(void); //Delay for 15 ms.
void DelayXLCD(void); //Delay for 5 ms.
void XLCD_init(void); //Initialize the LCD display
unsigned short read_ds1307(unsigned short addressReg); //Function to read from the DS1307
void write_ds1307(unsigned short addressReg,unsigned short w_dataReg); //Function to write to the DS1307
int Binary2BCD(int aa); //Convert Binary to BCD
int BCD2Binary(int aa); //Convert BCD to Binary
//*** Global variables ****
char time[] = "00:00:00 PM";
char date[] = "00-00-00";
int second;
int minute;
int hour;
int hr;
int day;
int dday;
int month;
int year;
int ap;
unsigned short set_count = 0;
short set;
void main(void)
// OSCCON=0x76; //Configure internal oscillator
XLCD_init(); // Initialize LCD
OpenI2C(MASTER, SLEW_OFF);// Initialize I2C module
SSPADD = 45; //100kHz Baud clock @8MHz = 19
//SSPADD = (FOSC/ Bit Rate) /4 - 1
//check for bus idle condition in multi master communication
IdleI2C();
StartI2C();
while ( SSPCON2bits.SEN );
putrsXLCD("Time:");
SetDDRamAddr(0x40);
putrsXLCD("Date:");
do{
//Read Time and Date, when simulating with proteus, it will pick up the system Clock
//from your PC and might display the AM if your PC time is in 24Hrs mode
hour= read_ds1307(0x02); //Read Hour
hr = hour & 0b00011111;
ap = hour & 0b00100000;
minute= read_ds1307(0x01); //Read minutes
second= read_ds1307(0x00); //Read seconds
dday= read_ds1307(0x03); //Read The day of the week (sunday to saturday)
day= read_ds1307(0x04); //Read The day of the week (1st to 31st)
month= read_ds1307(0x05); //Read month
year= read_ds1307(0x06); //Read year
time[0]=MSB(hr);
time[1]=LSB(hr);
time[3]=MSB(minute);
time[4]=LSB(minute);
time[6]=MSB(second);
time[7]=LSB(second);
date[0]=MSB(day);
date[1]=LSB(day);
date[3]=MSB(month);
date[4]=LSB(month);
date[6]=MSB(year);
date[7]=LSB(year);
if(ap)
time[9] = 'P';
time[10] = 'M';
else
time[9] = 'A';
time[10] = 'M';
//Display Time and Date in 12Hrs Mode (with PM or AM)
SetDDRamAddr(0x05);
putrsXLCD(time);
SetDDRamAddr(0x45);
putrsXLCD(date);
//Write Time and Date:
//1. To set the time, press the SET pushbutton once to select the Hour.
//2. Press the UP button to increament the Hour value or DOWN Button to decreament.
//3. Press the SET Button again to move to the right to modify the minute.
//4. Note when SET is in second position, pressing UP or Down will only reset the second value to 00
//5. Continue doing the same to set the date as well.
//6. Pressing the SET Button for the 7th time will exit the SET up mode
set = 0;
if(PORTCbits.RC0 == 0)
for(int c=0;c<=20;c++)__delay_ms(5); //wait for 100ms
set_count++;
if(set_count >= 7)
set_count = 0;
if(set_count)
if(PORTCbits.RC1 == 0)
set = 1;
if(PORTCbits.RC2 == 0)
set = -1;
if(set_count && set)
switch(set_count)
case 1:
hour = BCD2Binary(hour);
hour = hour + set;
hour = Binary2BCD(hour);
if((hour & 0x1F) >= 0x13)
hour = hour & 0b11100001;
hour = hour ^ 0x20;
else if((hour & 0x1F) <= 0x00)
hour = hour | 0b00010010;
hour = hour ^ 0x20;
write_ds1307(2, hour); //write hour
break;
case 2:
minute = BCD2Binary(minute);
minute = minute + set;
if(minute >= 60)
minute = 0;
if(minute < 0)
minute = 59;
minute = Binary2BCD(minute);
write_ds1307(1, minute); //write min
break;
case 3:
if(abs(set))
write_ds1307(0,0x00); //Reset second to 0 sec. and start Oscillator
break;
case 4:
day = BCD2Binary(day);
day = day + set;
day = Binary2BCD(day);
if(day >= 0x32)
day = 1;
if(day <= 0)
day = 0x31;
write_ds1307(4, day); // write date 17
break;
case 5:
month = BCD2Binary(month);
month = month + set;
month = Binary2BCD(month);
if(month > 0x12)
month = 1;
if(month <= 0)
month = 0x12;
write_ds1307(5,month); // write month 6 June
break;
case 6:
year = BCD2Binary(year);
year = year + set;
year = Binary2BCD(year);
if(year <= -1)
year = 0x99;
if(year >= 0x50)
year = 0;
write_ds1307(6, year); // write year
break;
} while(1);
unsigned short read_ds1307(unsigned short address) //call this function to read date and time
//from the date and time registers.
char r_data;
StartI2C(); // Start condition I2C on bus
IdleI2C();
WriteI2C( 0xD0 ); // addresses the chip
IdleI2C();
WriteI2C( address ); // write register address
IdleI2C();
StopI2C(); // Stop condition I2C on bus
RestartI2C(); // Start condition I2C on bus
IdleI2C();
WriteI2C( 0xD1 ); // addresses the chip with a read bit
IdleI2C();
r_data = ReadI2C(); // read the value from the RTC and store in result
IdleI2C();
NotAckI2C(); // Not Acknowledge condition.
IdleI2C();
return (r_data);
void write_ds1307(unsigned short address,unsigned short w_data) //call this function to write date and time
//to the date and time registers.
IdleI2C();
IdleI2C();
IdleI2C();
WriteI2C( w_data ); // write register address
IdleI2C();
int Binary2BCD(int a) //Convert Binary to BCD so we can write to the DS1307 Register in BCD
int t1, t2;
t1 = a%10;
t1 = t1 & 0x0F;
a = a/10;
t2 = a%10;
t2 = 0x0F & t2;
t2 = t2 << 4;
t2 = 0xF0 & t2;
t1 = t1 | t2;
return t1;
int BCD2Binary(int a) //Convert BCD to Binary so we can do some basic calculations
int r,t;
t = a & 0x0F;
r = t;
a = 0xF0 & a;
t = a >> 4;
t = 0x0F & t;
r = t*10 + r;
return r;
void XLCD_init(void){ //Initialize LCD display
OpenXLCD(FOUR_BIT&LINES_5X7);
while(BusyXLCD());
WriteCmdXLCD(0x06); // move cursor right, don?t shift display
WriteCmdXLCD(0x0C); //turn display on without cursor
putrsXLCD("Real Time Clock");
SetDDRamAddr(0x44);
putrsXLCD("Starting");
for(int c=0;c<=20;c++)__delay_ms(60);
SetDDRamAddr(0x44);
putrsXLCD("Starting.");
for(int c=0;c<=20;c++)__delay_ms(50);
SetDDRamAddr(0x44);
putrsXLCD("Starting..");
SetDDRamAddr(0x44);
putrsXLCD("Starting...");
WriteCmdXLCD(0x01); //Clear Screen
WriteCmdXLCD(0x02); //Go Home
void DelayFor18TCY( void ){
Delay10TCYx(20); //18 cycles delay
void DelayPORXLCD (void){
Delay1KTCYx(15); // Delay of 15ms
return;
}//End DelayPORXLCD
void DelayXLCD (void){
Delay1KTCYx(5); // Delay of 5ms
return;
