prograaming of ldr in c
14dhrumit
Member level 3
Hamilton, Ontario, Canada
i want to on-off my LED according to my LDR ,but i don't get it how to create a program in c for LDR on negative coefficient.
Off the top of my head - without being tested and without knowing your compiler or target processor -
Maybe something like...
#define led = PORTA.0
void main(void);
int adc_val;
    init_adc(1);
    while(1){
        read_adc(1);
        if(adc_val > 500){
            led = 0;
        if(adc_val < 480){
            led = 1;
I am using 89C52. i am using LDR for such a purpose that as the sun sets, the lights starts glowing slowly as the darkness increases..
If you want to control the brightness of the output lamp according to the adc value then you have to use a triac. If you just want to ON/OFF output with adc value then you don't need triac.
i am controlling it using a controller(89C52) and i just want to switch ON and OFF my LEDs using LDR. It is something like when the light is there, the LEDs won't glow but as soon as the light fades away the LEDs start glowing... And i want programming for that...
