taleebe
Newbie level 3
I'd like my DC voltage supply to have an AC ripple on it so that i may test PSRR of some DUT.I have this elaborate circuit built and it indeed produces such a supply upto 20MHz.first i built the circuit with a 100pf ceramic capacitor in place to block the signal generator from DC and was expecting some attenuation due to the resulting RC filter but as ive discovered the circuit produces a rippled supply even without a capacitor,However the AC ripple produced is attenuated and the attenuation factor increases with increasing frequency.Im comfortable with attenuation as i can just adjust amplitue using my signal generator but i am worried about the attenuation increasing with frequency. If i have a 200mv ripple i'd like it to stay at 200mv even when i change the frequency!Someone has suggested i buy a better scope but im not sure if thats it.
As a side note my DUT sinks up to 1A of current and i;m doing PSRR tests upto 20MHZ so conventional ways of producing a rippled supply(op amp,transformer in series with source,power FET) are out the door[/img]
