problom in Mplab x v2.0 programming.
tapu
Full Member level 4
india
Dear all,
I am new in mplab x or pic programming.as i have been used keil for 8051.first time i program pic 18f2220 in mplab x2.0 (xc8 compiler) for a simple program.But it shows errors in output as follow.
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory `C:/Users/lg/MPLABXProjects/test.X'
make -f nbproject/Makefile-default.mk dist/default/production/test.X.production.hex
make[2]: Entering directory `C:/Users/lg/MPLABXProjects/test.X'
"C:\Program Files (x86)\Microchip\xc8\v1.34\bin\xc8.exe" --pass1 --chip=18F2220 -Q -G --double=24 --float=24 --emi=wordwrite --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --asmlist --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,-download,+config,+clib,+plib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto:auto "--errformat=%%f:%%l: error: (%%n) %%s" "--warnformat=%%f:%%l: warning: (%%n) %%s" "--msgformat=%%f:%%l: advisory: (%%n) %%s" -obuild/default/production/test.p1 test.c
test.c:11: error: (192) undefined identifier "OSCON"
(908) exit status = 1
make[2]: Leaving directory `C:/Users/lg/MPLABXProjects/test.X'
make[1]: Leaving directory `C:/Users/lg/MPLABXProjects/test.X'
make[2]: *** [build/default/production/test.p1] Error 1
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
BUILD FAILED (exit value 2, total time: 678ms)
Now how to solve this issue.
Have you included linker file for the 18f2220 and header files also.
I have linked source file & header file also.
'OSCON' is undefined. Possible, syntax error or header incorrectly included. No idea without see the code.
Reactions: tapu
    tapu
Theire was a syntax error in osccon.I was written OSCON.
