Problems with SSD0323 OLED Controller interface
nagi
Newbie level 5
Newbie level 5
ssd0323
Hi;
I am trying to display few characters on OSRAM OLED display. I have been stuck on this one for last few days.
I did a small test by sending SWITCH ON ALL PIXELS command. Even then all the pixels are OFF.
How do I make sure that my display is actually initialised proplerly and accepting the commands. I have followed the initialisation sequence mentioned in the datashee.
If anybody has used these displays please give me the code.
regards
Nagi
oled controller
HI
Did you check whether the 12 HV supply is on ?
All the best
Bobi
ssd0323 initialization
Hi bobi;
Thanks for the reply. I made sure that 12V supply is ON. But the strange thing is that I don't see any voltage on VcomH and IRef pins. is it because of my initialization?
I am including my initialization code. Please let me know if there is any obvious thing in that.
Looking forward toyour reply.
cheers
Nagi
//========================== CLEAR DISPLAY ==============================================
void ClearDisplay(BYTE grayScale)
	int  ndx;
// Set Column Address
	WriteCommand(0x15);
	WriteCommand(0x00);
	WriteCommand(0x3F);
// Set Row Address
	WriteCommand(0x75);
	WriteCommand(0x00);
	WriteCommand(0x3F);
	DISPLAY_D_C =1;
	DISPLAY_CS_NOT =0;
	for(ndx =0; ndx < 4096; ndx++)
		LATE = grayScale;
		DISPLAY_WR_NOT=0;
		DISPLAY_WR_NOT=1;
	DISPLAY_CS_NOT =0;
//====================================WRITE DATA =============================================
void WriteData(unsigned char data)
	DISPLAY_D_C =1;//Data
	DISPLAY_CS_NOT =0;//Enable Chip Select
	LATE = data;
	DISPLAY_WR_NOT=0;
	DISPLAY_WR_NOT=1;//Write Strobe
	DISPLAY_CS_NOT=1;//disable chip select
	delay(1);
//===================================WRITE COMMNAD==============================================
void WriteCommand(BYTE command)
	DISPLAY_D_C =0;// Command
	LATE = command;
	DISPLAY_WR_NOT=0;
	delay(1);
//==================================== OSRAM INIT  ============================================
void OSRAM_Init(void)
	unsigned char i,j;
	//Assumption VCC_BAR supply is switched and stable(Controlled by Blackfin)
	// OSRAM
	delay(2);//wait untill Vdd is stable
	// Do hardware Reset
	DISPLAY_RST_NOT = 0;
	delay(100);//wait for 100mS
	DISPLAY_RST_NOT = 1;
	//Send Display OFF command
	WriteCommand(0xAE);
	//Switch on 12v Power Supply
	SWITCH_ON_5V = 1;//switch on 5v power supply
	DISPLAY_PWR = 1;//Switch ON display Power (12V)
	delay(100);//wait untill the 12v is stable
	//Column Address
	WriteCommand(0x15); /* Set Column Address */
	WriteCommand(0x00);  /* Start = 0 */
	WriteCommand(0x3F);  /* End = 127 */
	//Row Address
	WriteCommand(0x75);  /* Set Row Address */
	WriteCommand(0x3F);  /* End =  63 */
	// Contrast Control
	WriteCommand(0x81);  /* Set Contrast Control  */
	WriteCommand(0x6D);  /* 0 ~ 127 */
	// Current Range
	WriteCommand(0x86);  /* Set Current Range 84h:Quarter,  85h:Half, 86h:Full*/
	// Re-map
	WriteCommand(0xA0);  /* Set Re-map */
	WriteCommand(0x41); /* [0]:MX, [1]:Nibble, [2]:H/V address [4]:MY, [6]:Com Split Odd/Even "1000010"*/
	//Display Start Line
	WriteCommand(0xA1); /* Set Display Start Line */
	WriteCommand(0x00); /* Top */
	//Display Offset
	WriteCommand(0xA2); /* Set Display Offset */
	WriteCommand(0x44); /* Offset 76 rows */
	//Display Mode
	WriteCommand(0xA4);  /* Set DisplaMode,A4:Normal,   A5:All ON, A6: All OFF, A7:Inverse */
	// Multiplex Ratio
	WriteCommand(0xA8); /* Set Multiplex Ratio */
	WriteCommand(0x3F); /* 64 mux*/
	// Phase Length
	WriteCommand(0xB1); /* Set Phase Length */
	WriteCommand(0x22); /* [3:0]:Phase 1 period of 1~16 clocks */
	                                      /* [7:4]:Phase 2 period of 1~16 clocks /* POR = 0111 0100 */
	// Row Period
	WriteCommand(0xB2); /* Set Row Period */
	WriteCommand(0x46); /* [7:0]:18~255, K=P1+P2+GS15 (POR:4+7+29)*/
	// Display Clock Divide
	WriteCommand(0xB3); /* Set Clock Divide  */
	WriteCommand(0x91); /* [3:0]:1~16, [7:4]:0~16, 100Hz */
	 /* POR = 0000 0001 */
	// VSL
	WriteCommand(0xBF); /* Set VSL */
	WriteCommand(0x0D);  /* [3:0]:VSL */
	// VCOMH
	WriteCommand(0xBE); /* Set VCOMH  */
	WriteCommand(0x02);  /* [7:0]:VCOMH, (0.53 X Vref = 0.53 X 15 V = 7.95V)*/
	// VP
	WriteCommand(0xBC); /* Set VP  */
	WriteCommand(0x10);  /* [7:0]:VP, (0.67 X Vref = 0.67 X 15 V = 10.05V) */
	// Gamma
	 WriteCommand(0xB8); /* Set Gamma with next 8 bytes */
	 WriteCommand(0x01);  /* L1[2:1] */
	 WriteCommand(0x11); /* L3[6:4], L2[2:0] 0001 0001 */
	 WriteCommand(0x22); /* L5[6:4], L4[2:0] 0010 0010 */
	 WriteCommand(0x32); /* L7[6:4], L6[2:0] 0011 1011 */
	 WriteCommand(0x43); /* L9[6:4], L8[2:0] 0100 0100 */
	 WriteCommand(0x54); /* LB[6:4], LA[2:0] 0101 0101 */
	 WriteCommand(0x65); /* LD[6:4], LC[2:0] 0110 0110 */
	 WriteCommand(0x76); /* LF[6:4], LE[2:0] 1000 0111 */
	// Set DC-DC
	 WriteCommand(0xAD); /* Set DC-DC */
	 WriteCommand(0x02);  /* 03=ON, 02=Off */
	// Display ON/OFF
	 WriteCommand(0xAF); /* AF=ON, AE=Sleep Mode */
