Problems with rotary encoder project
2000
Member level 5
Member level 5
Encoder problems
Hello friends,
Once more I need your help. I´m working on a rotary encoder that generates 50 pulses/turn. One of the direction signals is conected directly to the interruption of the 8051 and the other is connected to the P0^3 port, in such a way that when an interruption is generated by a falling edge the P0^3 is checked to see if its 1 or 0 to determine the direction of rotation.
The problem is, when spinning fast the 8051 interprets well the signals and works fine, but when spinning slow it doesn´t know the direction and get lost. What could be wrong? I´ve already looked the signals in a LA and there is no bouncing or glitches. Should I use any logic?
regards,
2000
encoder
hi 2000,
i finally uploadet an image of quadrature encoder.
hope this image is clearing up a bit.
( i'ts just a scratch draw of principle )
hxxp://www.angelfire.com/freak/gelly/encoder_mouse.jpg
about the problem u just having...
cant say mutch, because of too less info on whole project.
gelly.
The problem could be a slow transition for low velocity. Remember that
the external INT sources are edge triggered. Then maybe you never generates a trigger at low vel. Try connecting an schmitt trigger gate as the 4106 not gate, it compares level voltage and generates steep pulses
Also I recommned you to introduce a little delay after the lecture of port to make sure that cuadrature pulse has arrived.
Please tell more details if problem persist
NEBISMAN
Re: Encoder problems
Did you look at the A and B channel by scop ?
Signals are good at all speed?
Try it:
Connect encoder's clock pulse to 8051's interrupt input. When clock pulse trigged low scan direction bit.
I think it will work.
You can try...
- Using Counter Mode
Count limit sets to '1' and input
If counted and interupt.
LaTeX Commands Quick-Menu:
