OvErFlO
Full Member level 3
Phase Shifter Simulation
I have write this code to use 2 signals with a 90° fase shifter...
There's a clock of 500Khz
When I try to do a Logical Simulation with ModelSim it's works
If I try to do a Place&Route Simulation clk_90 is 'X'
But when I use Active HDL in both case I have a good results.. Why ?
Thanks
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Uncomment the following lines to use the declarations that are
-- provided for instantiating Xilinx primitive components.
library UNISIM;
use UNISIM.VComponents.all;
entity clock_phase is
Port ( clk_in : in std_logic;
clk_x2 : out std_logic;
clk_0 : out std_logic;
clk_90 : out std_logic);
end clock_phase;
architecture Behavioral of clock_phase is
component IBUFG
port (I: in std_logic; O: out std_logic);
end component;
signal clk_in1,net1,net2,net3,net4 : std_logic := '0';
begin
U1: IBUFG port map (I => clk_in, O => clk_in1);
div_clock : process (clk_in1)
begin
if (rising_edge (clk_in1)) then
net1<= not net1;
end if;
end process div_clock;
div_clock2 : process (clk_in1)
begin
if (falling_edge (clk_in1)) then
net2<= not net2;
end if;
end process div_clock2;
clk_0 <= net1;
clk_90 <= net2;
clk_x2 <= clk_in1;
end Behavioral;
Thanks
