BrunoARG
Full Member level 4
- Joined
- Aug 15, 2014
- Messages
- 214
- Helped
- 38
- Reputation
- 76
- Reaction score
- 38
- Trophy points
- 28
- Location
- Buenos Aires, Argentina
- Activity points
- 2,177
Hello everyone.
I am using a opamp active integrator (with schmitt trigger) at a very low frequency (500mHz).
The matter is that the integrator R-C values are 56K and 10uF. I build the circuit in a breadboard and measure the capacitor voltage. It's a contiunous voltage of 5.4V (half the value of the opamp VOH. I am using LM358 which reachs the negative rail). I don't know why it gets stuck in that value.
The capacitor used is a 10uF electrolytic one, I am sure it's not broken or burned out. I simulated the circuit with LTspice and it didn't work. I changed its value to 1uF and it worked well.
Then I changed the value to 1uF in the breadboard and it started to work (with a frequency variation but the triangle wave was there). Then I tried decreasing the power soure voltage and it worked. I changed to the 10uF capacitor again and supplying with 8V it worked. Then I put a 10uF TANTLUM one and worked. I raised the power supply to 12V again and was still working. I turned again to the 10uF electrolytic one and didn't work. I tried again with the tantalum one but didn't worked. I tried to repeat the process but it didn't work any more.
What I find strange is that the calcules are right and it should work, but neither in the simulation and in the breadboard it does. I changed the capacitor value to another and it worked. I thought about the capacitor type being wrong (electrolytic) but it worked with the 1uF one.
I've been reading and I found something about capacitors dielectric absorption, which was bad for capacitors used on integrators. The other thing I thought about is the current loss, making it unable to charge at all, but then I realised that it should charge slower but it would reach the schmitt trigger threshold value. The last option possible is that the capacitor is charged with 10.5V and the threshold is about 9V. Is it so high that it doesn't charge at all?
I honestly don't know what to think about, it's so strange, it's the very first time it happens to me.
Thank you in advance.
