Elephantus
Junior Member level 3
isplever problem process and signal
Hi all. I am trying to build a design for lattice ECP2 fpga and the ispLEVER map returns the following error:
"This device does not allow routing COUT signal of RIPPLE comp
using regular routing resources. Signal
'u_ctrl/brst_x_1_cry_12' of comp
'u_ctrl/brst_x_1_cry_11_0' must drive
CIN of RIPPLE and use fast carry. Please check your design."
Now, the only place in the code where brst_x is assigned, is this:
The error would suggest that something is wrong in the synthesis of the subtract operation. One thing is, brst_x and brst are 32 bit values, x is a 13 bit value - however this synthesized well using xilinx xst. Has anyone experienced problems such as these?
I would appreciate any help.
process (gsr, clk)
begin
if (gsr = '1') then
brst_x <= (others => '0');
elsif (rising_edge(clk)) then
brst_x<= brst - x;
end if;
end process;
