Problems with designing in Microwave Office
Javirulo
Newbie level 6
Newbie level 6
Spain
doubt with MWO
Hi, I've and important question about Microwave Office. I've designed a printed antenna that works perfectly when I simulate it but the measurements in laboratory are completely different. I think the problem could be in the ports. I use an edge port to feed the antenna using coplanar feeding, but I don't know if the simulator understand where is the ground or if I have to define it elsewhere ( once the antenna is built I feed it using SMA connector ans I put the ground pins at both sides of the coplanar line ). Any help could be grateful
[/img]
Re: doubt with MWO
Hello Javirulo
See the attached documents from Sonnet Software...
It is some what similar simulation setup you need to do for CPW applications in MWO...
---manju---
