Problems with coding autonomous mobile robot
robot032
Newbie level 1
egypt
Autonomous Mobile Robot
hi, i want to make autonomous mobile robot will send signal from atmega16 uc to servo motor according to signal coming from infrared sensor, if sensor detect obstacle the Robot will send signal to servo motors to avoid obstacle ,Robot in same time will send signal to computer via RF module to drawing path
while (1)
      // Place your code here
      int forward=0x00;
      int left_P=0x01;
      int left=0x02;
      int Right=0x03;
      int back=0x04;
      bit x;
      unsigned int counter;
      if (TIFR==0x01)
          counter++;
      while(read_adc(0x00) < 127)     //if the sensor not detect object-----------------------------
         //printf("Forward");
         PORTC=0x05;                  //go forward
         x=0;
      while(read_adc(0x00) >= 127)    //if the sensor detect object---------------------------------
         /*if  the main sensor read object .so, go to two Edge Sensor
              left sensor  |   Right sensor  |  state
                  0        |         0       |  go left(priroty)
                  0        |         1       |  go left 90 degree
                  1        |         0       |  go Right 90 degree
                  1        |         1       |  go left 180 degree
                  in all previous cases the main sensor value is 1 .
         if (PINB==0x00)               //if both edge sensor not
         if(x==0)
         TCCR0=0x03;                  //start timer
         PORTC=0x09;                  //go to left
         delay_ms(1);
         counter++;                   //if the over flow occur the 'countr' variable increase by 1
         x=1;
         //printf("%x",left_P);
         if (counter>5000)            //if access to 5000 overflow means the robot rotate to left
         PORTC=0x00;                  //stop
         TCCR0=0x00;                  //then stop timer
         counter=0;                   //zeros the variable counter
        if (PINB==0x01)
         if(x==0)
         delay_ms(1);
         x=1;
         //printf("%x",left);
         PORTC=0x00;                  //stop
          if (PINB==0x02)
         if(x==0)
         PORTC=0x06;                  //go to Right
         delay_ms(1);
         x=1;
         //printf("%x",Right);
         PORTC=0x00;                  //stop
         if (PINB==0x03)              //if the two Edge  sensor detect
         if(x==0)
         PORTC=0x09;                  //go to left 180 degree
         delay_ms(1);
         x=1;
         //printf("%x",back);
         if (counter>10000)            //if access to 5000 overflow means the robot rotate to left
         PORTC=0x00;                  //stop
but i have problem simulation is work very will, but in practical the Robot does not work as I want..
Note:
am use code vision AVR
and protus7
i am sorry for bad language.
happy new year
sami
