Hi, there~
after the ac, dc, stb, simulation are all done, i save the scripts in the ADE, and i open the ocean and load the script i saved just now, but an error is encountered, listed below:
The directory you specified does not contain valid PSF results.
Please check the line for typographical errors or look in the directory for a logFile and PSF result files.
Please specify a results directory.
Copy down the full path during these "save" operations,
and the results path from the simulation (ADE) setup.
Then see whether the psf path particularly, is called out
in the Ocean script the same (no relative paths, etc.).
I would suspect that the ADE environment differs from
the cdsWrapper>Ocean environment somehow in this vein.
The syntax Ocean requires, I can't help you with. But this
is what those errors indicate to me.
