Problem with Windows C drive on Linux
hemanth
Junior Member level 2
Allahabad,India
i mounted the windows c drive in linux after some time it was not resopnding the i loged out and shut down the system. when i started the system it is not booting in windows saying that
rootverify(hd0,0)
chainloader +1
NTLDR is missing
Re: linux problem
try this
Re: linux problem
Try this....
Insert your windows CD and follow the wizard until it asks you to install, at this point choose the option to repair, this option boots the machine in the repair console of microsoft.
Type de administrator password and the prompt should appear. At the command prompt type "fixboot"
This command will fix the boot registries on the machine and will restore the ntldr archive.
Hope it helped.
