i have a VCO working at 2.4 GHz
i should match its output for maximum power transfer
i measured its output impedence, and i put a matching load Zload = Zout*
but when i did that, no output from VCO and the oscillation is dead.
I think you have to match the VCO after buffer with capacitive input. Because the load has big influence on VCO feedback as consequence on VCO oscillation.
u mean to use a buffer between the VCO and and outer world?
that buffer is an RF buffer so, it is hard to implement.
also, should i match between the VCO and the buffer?
do u have a good paper or toturial to implement this buffer?
and does that buffer have an inductor?
another bad thing???????
