What is input signal in your circuit? How do you measure it? How should the problem be related to uA733?The input signal is 30mv,17MHz.I expected about 300mv.
Input is biased to mid supply, no problem.The datasheet doesn't seem to say it can be used in a single supply configuration
Good morning.I have just returned from night shift.I have two resistorInput is biased to mid supply, no problem.
;*********************************************8888Hi,
May I ask why you use a differential amlifier when you just use one output?
To measure gain you need to involve both outputs: Vout = VOut+ - VOut-
Just to talk about the same datasheet: which amplifier exactly arou you using: LM733 or uA733? Which package?
Klaus
;*********************************************************88Can we please clarify the post #4 question. What's the oscillator type and has it really low output voltage in the 100 mV range, or even less?
;******************************************************What puzzles me is the pins of TX1 suggest it is a metal can package with pins to fit a 14-pin DIL profile. That almost certainly means it produces TTL level outputs. If I'm right, TX1 pin 8 should connect directly to the 'D' input of the flip-flop and the LM733 isn't needed at all.
Brian.
