Problem with using Cadence Virtuoso 5.033 on RedHat 9
tran
Member level 4
Hi all,
I have installed Cadence Virtuoso 5.0.33. I use Redhat9. And there are some error:
When I start virtuoso there is a warning :
' Incorrectly built in binary which accesses errno, h_errno or_res directly. Needs to be fixed.'
And some functions can not use : can't use some buttons, can't double click to chose file (must type the file name and chose OK) ....
Can somone help me to solve those errors ?
Thank you very much!!
virtuoso on rehat9
Pls. change to another RH platform.
virtuoso on rehat9
You can use RH 7.2 or RHEL 2\3.
virtuoso on rehat9
Try insert "export LD_ASSUME_KERNEL=2.4.1" in ur .bashrc file.
