markdem
Member level 3
Hi All, I have finally got my ADE7753 talking to my PIC, I can read all the non-zero registers, get the die revision and read the period time.
I cant, however, get the VRMS and IRMS working. I can read the register OK, but i get unstable numbers, ranging from 20000 to 60000, even when I short the inputs. I think that this may be a hardware problem. I have looked at AN564 from analog, and there is something that I am not to sure about.
In the diagram for the power supply, it shows the analog ground connected to the 240VAC neutral line, there for connecting the ground from the 7805 to it. Is this correct?
Currently I have a simple 7805 power supply for the PIC, ADE7753 and my LCD, and then I have a resistor divider to reduce the 240VAC down to 470mV for the ADE7753.
The regulator and resistor divider and not connected in any way. Is this how it should be, or am I getting something very wrong.
Thanks
Mark
Thanks
Mark
