Top side SMT component should accept only top trace but instead it is accepting both the top aswell as bottom trace without via.Here I'm using PAD Power PCB version -3.0.
Now I'm doing 6 layer board. Top and bottom used for componet placement . Remaining layers 2 and 5 for ground and power. 3 and 4 for routing. this top layer SMT component's pad should accept only top trace instead it is accepting all layer trace without via.
Its not possible for routing a top mounted smt component in bottom layer this is conformed .But you say that you are able to route so i think just you can view it but if it ends it will end only in via.
