Problem with PWM programming in mikroC pro
Cheetos
Member level 3
Member level 3
I'm having a problem with mikroC PRO
i am using PIC16F877a and 8MHz xtal
This is my code and i always get Undeclared identifier on all PWM related codes.. please help me
void InitMain() {
PORTB = 0; // set PORTB to 0
TRISB = 0xF0; // designate PORTB pins as output
PORTC = 0; // set PORTC to 0
TRISC = 0xFF; // designate PORTC pins as output
Pwm1_Init(5000); // Initialize PWM1 module at 5KHz
PWM2_Init(5000); // Initialize PWM2 module at 5KHz
void main(){
InitMain();
PWM1_start();
PWM2_start();
while (1) {
if(PORTB==0x80)
PORTB=0x01;
if(PORTB==0x40)
PORTB=0x00;
Pwm1_Change_Duty(30);
if(PORTB==0x20)
PORTB=0x00;
Pwm1_Change_Duty(15);
if(PORTB==0x10)
PORTB=0x00;
Pwm1_Change_Duty(0);
post the complete code with the header files used in program and the list of errors you get as snapshot or copy paste so that we can see you.....
Thank you for your reply. That's all of my codes, i have no header files. my program is just a simple PWM..
These are my errors :(
 * this example smoothly blinks LEDs on RC1 and RC2 alternatvely
 * using PIC CCP module configured as PWM output
 * source code example for mikroC
 * feel free to use this code at your own risks
 * target : PIC16F877A, 8 Mhz crystal
 * HS clock, no watchdog.
 * easyPIC4 settings :
 *      LEDs on PORTC enabled
 * Author : Bruno Gavand, September 2007
 * see more details on http://www.micro-examples.com/
void main()
        unsigned char   dc ;
        TRISC = 0 ;                     // set PORTC as output
        PORTC = 0 ;                     // clear PORTC
         * configure CCP module as 4000 Hz PWM output
        PR2 = 0b01111100 ;
        T2CON = 0b00000101 ;
        CCP1CON = 0b00001100 ;
        CCP2CON = 0b00111100 ;
        for(;;)                         // forever
                 * PWM resolution is 10 bits
                 * don't use last 2 less significant bits CCPxCON,
                 * so only CCPRxL have to be touched to change duty cycle
                for(dc = 0 ; dc < 128 ; dc++)
                        CCPR1L = dc ;
                        CCPR2L = 128 - dc ;
                        Delay_ms(10) ;
                for(dc = 127 ; dc > 0 ; dc--)
                        CCPR1L = dc ;
                        CCPR2L = 128 - dc ;
                        Delay_ms(10) ;
Change your code to:
void InitMain() {
void main(){
InitMain();
PWM1_start();
PWM2_start();
while (1) {
if(PORTB==0x80)
PORTB=0x01;
if(PORTB==0x40)
PORTB=0x00;
Pwm1_Set_Duty(30); ///// Difference here ----------------
if(PORTB==0x20)
PORTB=0x00;
Pwm1_Set_Duty(15); ///// Difference here ----------------
if(PORTB==0x10)
PORTB=0x00;
Pwm1_Set_Duty(0); ///// Difference here ----------------
The difference is pretty straightforward. The problem was that in the old mikroC compilers, you changed the duty cycle by writing:
Pwm1_Change_Duty
However after the newer "mikroC PRO for PIC" series was released, it was changed to:
Pwm1_Set_Duty
If you run your code on the old compilers (don't remember which version, but not mikroC PRO for PIC), it will compile fine.
Try the code I posted. It compiles just fine.
You can view all the library functions by selecting "Help" from the Help menu or simply by pressing F1! :smile:
Hope this helps.
Tahmid.
---------- Post added at 00:41 ---------- Previous post was at 00:35 ----------
In mikroC, you do not need to declare header files separately. By default, all "header and library files" are loaded. You can choose to set which "header files" to load by clicking on the Library Manager and then selecting from the list:
:smile:
Hope this helps.
Tahmid.
