usmani
please check and correct the code.
i am using 89c2051 microcontroller. normally at pin p3.2 and p3.3 signal is high (4.8v) i what to generate pwm signal when signal goes low on p3.2, and when signal goes low on p3.3 decreasing pwm should be generated at p1.6.
#include <reg51.h>
#include <intrins.h>
sbit PWM_OUT=P1^6;
sbit GREEN_SIG=P3^2;
sbit RED_SIG=P3^3;
unsigned char duty_cycle=1;
#define PULSES_LIMIT 1000
#define ON 1
#define OFF 0
//Delay Function
void Delay5Us(unsigned char delay)
while(delay)
delay--;
_nop_();
}//DelayUs
void RunCar()
unsigned int pulse_count=0;
duty_cycle=20;
while(GREEN_SIG=0)
// while(0)
PWM_OUT=MOTOR_ON;
if(duty_cycle<60)
if(pulse_count==PULSES_LIMIT)
duty_cycle++;
pulse_count=0;
pulse_count++;
Delay5Us(duty_cycle*10);
PWM_OUT=MOTOR_OFF;
Delay5Us((20-duty_cycle)*10);
}//RunCar
void StopCar()
PWM_OUT=0;
}//StopCar
void main()
PWM_OUT=OFF;
while(1)
if (Green_Sig==0)
RunCar();
}//iff
else if(RED_SIG==0)
StopCar();
}//else if
}//while
}//main
#include <reg51.h>
sbit PWM_OUT=P1^6;
sbit RED_SIG=P3^3;
#define ON 1
#define OFF 0
//Delay Function
while(delay)
delay--;
_nop_();
}//DelayUs
void RunCar()
duty_cycle=20;
while(GREEN_SIG=0)
// while(0)
PWM_OUT=MOTOR_ON;
if(duty_cycle<60)
duty_cycle++;
pulse_count=0;
pulse_count++;
PWM_OUT=MOTOR_OFF;
}//RunCar
void StopCar()
PWM_OUT=0;
}//StopCar
void main()
PWM_OUT=OFF;
while(1)
if (Green_Sig==0)
RunCar();
}//iff
else if(RED_SIG==0)
StopCar();
}//else if
}//while
}//main
