Problem with pic program [SOLVED].
Eraser
Member level 3
Member level 3
Braga,Portugal
void interrupt my_isr(void)
I built this program, in c , this is a led pingpong, on pic 16f877a, but the program doesnt work 100%, the leds move for one side and dont return, and i dont know why.
Can anyone help me???
the program is :
#include <htc.h>
int direction=0;
__CONFIG(XT & WDTDIS & PWRTDIS & BORDIS & LVPEN & WRTEN & DEBUGDIS & DUNPROT & UNPROTECT);
void inittimer0(void)
T0CS=0;
T0SE=0;
PSA=0;
PS2=1;
PS1=1;
PS0=1;
TMR0=0;
void initporto(void)
TRISD=0;
PORTD=0;
RD7=1;
void interrupcoes(void)
T0IF=0;
T0IE=1;
GIE=1;
void main(void)
inittimer0();
initporto();
interrupcoes();
while (1)
if (direction==0)
T0IF=0;
PORTD=PORTD*10;
if (RD0==1)
direction=1;
else
T0IF=0;
PORTD=PORTD/10;
if (RD7==1)
direction=0;
Problem with pic program.
can u give us the schematic?
Re: Problem with pic program.
The problem its not hardware, because i made the same program in assembley, and work,im learning c so i am a roockie.lol
thanks.
I don't see which bit pattern is intended or how PORTD=PORTD*10 respectively PORTD=PORTD/10 can generate a useful pattern.
I have tried put portd=portd>>1 and portd=portd<<1, and the result its the same.
Hi!
I have tested this code in proteus. It works fine. So test this on ur hardware.
I hope this will be successfull.
Regards.
#include <htc.h>
int direction=0;
T0CS=0;
T0SE=0;
PSA=0;
PS2=1;
PS1=1;
PS0=1;
TMR0=0;
TRISD=0;
PORTD=0;
RD7=1;
T0IF=0;
T0IE=1;
GIE=1;
void main(void)
inittimer0();
initporto();
interrupcoes();
while (1)
if (direction==0)
T0IF=0;
PORTD=PORTD>>1;
if (RD0==1)
direction=1;
else
T0IF=0;
PORTD=PORTD<<1;
if (RD7==1)
direction=0;
At least, the code looks meaningful now.
sorry for my ignorance, but what is the proteus?
ohh
PORTD=PORTD<<1; ???
don't do this way
use a variable to shift in PORT
for example:
unsigned char c=80;
PORTD=c>>i;
Pallav Aggarwal
Simpaltechnologies,India
Eraser said:
The program already works. Thanks.
Could you please edit the topic to read "Problem with pic program [SOLVED]"? This would help prevent people from reading through the whole thread just to realize that there is now no problems to solve. Thank you.
Cheers,
Cheers,
Ok no problem.
