hello:
I got a strange problem with my layout when using calibre to do LVS.
I just drew a 4 times big inverter and compared it with spice netlist.
while the 4x inverter in the netlist is instantiated from a min-sized inverter like the following:
.param W=0.15u
.subckt inv in out vdd vss size=1
xmn out in vss vss wn='size*W' ....
xmp out in vdd vdd wp='size*W' ...
.ends
xinv4x in out vdd vss inv size=4
as you see, "size" is a parameter specified in the subckt.
after LVS, calibre told me that there is property error in the comparison.
the xtor size in layout doesn't match that in the netstlist (xinv4x).
actually I found that the size in layout is correct while the value of the parameter "size" in xinv4x is not transfered down to the inv subckt netlist.
does anybody have some idea to solve this problem?
thanks a lot
