lmtg
Member level 3
Compiling simprim library in xilinx I get:
--> Compiling verilog simprim library
> Simprim compiled to C:\Xilinx92i\verilog\mti_se\simprims_ver
> Log file C:\Xilinx92i\verilog\mti_se\simprims_ver\cxl_simprim.log generated
> Library mapping successful, setup file(s) modelsim.ini updated
compxlib[simprims_ver]: No error(s), no warning(s)
Output directory => 'C:\Xilinx92i\vhdl\mti_se'
--> Compiling vhdl simprim library
> Simprim compiled to C:\Xilinx92i\vhdl\mti_se\simprim
> Log file C:\Xilinx92i\vhdl\mti_se\simprim\cxl_simprim.log generated
compxlib[simprim]: 8 error(s), 1047 warning(s)
Log file (compxlib.log) generated.
Process "Compile HDL Simulation Libraries" failed
Q. Anybody has any idea what is wrong with simprim for vhdl...
I ignore the errors and simulate on modelsim. It in turn gives me the warnings:
** Warning: (vsim-3473) Component instance "madd_s_expsum_addsub0000_xor_1_q : x_xor2" is not bound.
# Time: 0 ps Iteration: 0 Region: /addexpunsig File: netgen/translate/AddExpUnsig_translate.vhd
# ** Warning: (vsim-3473) Component instance "madd_s_expsum_addsub0000_xor_2_q : x_xor2" is not bound.
# ** Warning: (vsim-3473) Component instance "madd_s_expsum_addsub0000_xor_3_q : x_xor2" is not bound
Are these errors related?? How can I solve them??
