problem with if generate statement
kakarala
Member level 1
HI i am trying to use if generate statement . Here i declared rp as constant array in a package and rp_x as a signal. When i am synthesizing it gives me the following error
ERROR:HDLParsers:1305 result of operator = is not static.
A :if rp(rp_x) = 1 generate
p1 <= p-stepsize;
sad02 : SAD4X4 port map(clk => clk, rst => rst,currblk_row => a,currblk_column => b,refblk_row => p1,refblk_column => q,sad => sad1);
end generate ;
every term in "rp(rp_x)" must be constant. generates aren't going to work the way you want them to.
Generates are filled out at elaboration time, not run time, hence why they need to be static. The implemented SAD4X4 cannot be implemented and removed on the fly.
I think that u can't using both blocking and non blocking statement in your program. try to use the if rp(rp_x) <= 1 generate.
sorry for that ans. I am new member of that forum and also i know only for verilog hdl that's why i give that ans.
