problem with getkey function on 8051 in c
vacant34
Newbie level 3
hi everybody
im am building a lcd with a keypad it also has a software clock
i have a issue with using the getkey() function in c. I want to ignore the function unless the dav changes
but what iv tried has not worked so far and the program gets stuck on getkey() and messes up the clock.
I know I could use a timer to build the clock but for know id just like to ignore the getkey() until is need it
so could i get some idea how to do this or a simple code for a clock based in the timers.
thank you
while(DAV==1);
getkey(key);
unsigned char getkey(unsigned char key)
//unsigned char key;
while(!DAV);
key=P1&0x0f;
while(DAV);
return key;
I'm not quite sure if I understand what you mean, but if you need to periodically check for button event try this:
unsigned char key_event(void)
[INDENT]static unsigned char LastState;
unsigned char pin_state;
unsigned char event = 0;
pin_state = P1 & 0x01;    // Or whatever is your port read methode
if(pin_state != LastState && pin_state)
[INDENT]event = 1;[/INDENT]
LastState = pin_state;
return event;[/INDENT]
If you place this function inside your loop you can check for button event not interrupting other stuff.
while(DAV==1);
getkey(key);
while(!DAV);
key=P1&0x0f;
while(DAV);
return key;
I think the problem is in code :
you're returning "key", but where ??
it should be like :
dummy = getkey(key);
or
getkey(&key);
out of above to option you need to change the getkey function corresponding to the option you've chose.
for more detail please see this : (see the call be reference section - you should use that section in your case)
https://www.codingunit.com/c-tutorial-call-by-value-or-call-by-reference
hi i know that code looks pretty bad but iv been messing with it so long iv just ended up trying stuff.
that part of the code works but will wait for a kepress and i want to ignore it unless we get that keypress its slowing down my clock. it will return a value to the main.
but i think i will find it worth going over again to see where i have any logicial mistakes thank you
thank you that looks pretty good i try that as soon as i get home.hopefully the getkey will be ignored unless it gets the keypress
