alexma
Newbie level 3
aggregate expression cannot be scalar type
I have a problem when program the FPGA using VHDL connecting to A to D Converter (TLC548I), the error came out as follow:
** Error: H:/D4/FPGA1/ADCmem.vhd(50): Aggregate expression cannot be scalar type std_logic.
** Error: H:/D4/FPGA1/ADCmem.vhd(53): Cannot resolve indexed name as type std_logic.
** Error: H:/D4/FPGA1/ADCmem.vhd(56): Assignment target type std_ulogic_vector is different from expression type std_logic.
** Error: H:/D4/FPGA1/ADCmem.vhd(75): Assignment target type std_ulogic_vector is different from expression type std_logic.
** Error: H:/D4/FPGA1/ADCmem.vhd(88): Assignment target type std_ulogic_vector is different from expression type std_logic.
** Error: H:/D4/FPGA1/ADCmem.vhd(101): Assignment target type std_ulogic_vector is different from expression type std_logic.
** Error: H:/D4/FPGA1/ADCmem.vhd(114): Assignment target type std_ulogic_vector is different from expression type std_logic.
** Error: H:/D4/FPGA1/ADCmem.vhd(127): Assignment target type std_ulogic_vector is different from expression type std_logic.
** Error: H:/D4/FPGA1/ADCmem.vhd(140): Assignment target type std_ulogic_vector is different from expression type std_logic.
** Error: H:/D4/FPGA1/ADCmem.vhd(153): Assignment target type std_ulogic_vector is different from expression type std_logic.
** Error: H:/D4/FPGA1/ADCmem.vhd(166): Assignment target type std_ulogic_vector is different from expression type std_logic.
the (incomplete) codes are as follow:
library ieee;
use ieee.std_logic_1164.all; -- include definition of std_logic
entity adc is
port (input,clock: in std_logic; ioclock, scl_out, sda_out ,cselect: out std_logic;
output : inout std_logic);
end entity adc;
architecture behaviour of adc is
type state is ( s0,s1,s2,s3,s4,s5,s6,s7,s8);
signal current_state, next_state : state;
signal ioclk, scl : std_logic :='0';
signal sda : std_logic := '1';
signal cs :std_logic := '1';
signal ram_CS,ram_WE,ram_OE : std_logic;
signal addr : integer range 0 to 7;
begin
seq: process(clock) is
begin
ioclock <= ioclk;
scl_out <= scl;
sda_out <= sda;
cs <='1'; --initial value
cselect <= cs;
ioclk <= not ioclk after 250 ns;
ioclock <= ioclk;
scl <= not scl after 250 ns;
scl_out <= scl;
cs <= '0';
cselect <= cs;
-- wait for 1400 ns; -- not sure
current_state<= s0;
if falling_edge(clock) then
current_state <= next_state;
end if;
end process seq;
com: process(current_state,cs,ioclk, addr,ram_CS, ram_WE,ram_OE) is
type ram_array is array (0 to 7) of std_ulogic_vector(7 downto 0);
variable mem: ram_array;
variable cnt: integer := 0;
begin
output <= (others => 'Z');
if ram_CS = '0' then
if ram_OE = '0' then
output <= mem(addr);
elsif ram_WE = '0' then
mem(addr) := output;
end if;
end if;
case current_state is
when s0=>
if (cs = '0') and (ioclk = '0') then
while not (cnt = 12) loop
if rising_edge(clock) then
cnt := cnt + 1;
end if;
end loop;
ram_CS <= '0';
ram_OE <= '1';
ram_WE <= '0';
addr <= 0;
mem(addr) := output; -- not finish
next_state <= s1;
else next_state <= s0;
end if;
when s1=>
if (cs= '0') and (ioclk = '0')then
ram_CS <= '0';
ram_OE <= '1';
ram_WE <= '0';
addr <= 1;
next_state <= s2;
else next_state <= s1;
end if;
when s2=>
if (cs= '0') and (ioclk) = '0'then
ram_CS <= '0';
ram_OE <= '1';
ram_WE <= '0';
addr <= 2;
next_state <= s3;
else next_state <= s2;
end if;
when s3=>
ram_CS <= '0';
ram_OE <= '1';
ram_WE <= '0';
addr <= 3;
next_state <= s4;
else next_state <= s3;
end if;
when s4=>
ram_CS <= '0';
ram_OE <= '1';
ram_WE <= '0';
addr <= 4;
next_state <= s5;
else next_state <= s4;
end if;
when s5=>
if (cs= '0')and(ioclk = '0') then
ram_CS <= '0';
ram_OE <= '1';
ram_WE <= '0';
addr <= 5;
next_state <= s6;
else next_state <= s5;
end if;
when s6=>
ram_CS <= '0';
ram_OE <= '1';
ram_WE <= '0';
addr <= 6;
next_state <= s7;
else next_state <= s6;
end if;
when s7=>
ram_CS <= '0';
ram_OE <= '1';
ram_WE <= '0';
addr <= 7;
--next_state <= s0;
next_state <= s8;
cs <= '1';
cselect <= cs;
else next_state <= s7;
end if;
when s8 =>
-- if scl = 1 then
-- sda <= 0;
next_state <= s0;
end case;
end process com;
end architecture behaviour;
library ieee;
entity adc is
end entity adc;
begin
begin
ioclock <= ioclk;
scl_out <= scl;
sda_out <= sda;
cselect <= cs;
ioclock <= ioclk;
scl_out <= scl;
cs <= '0';
cselect <= cs;
current_state<= s0;
end if;
end process seq;
begin
end if;
end if;
when s0=>
cnt := cnt + 1;
end if;
end loop;
ram_CS <= '0';
ram_OE <= '1';
ram_WE <= '0';
addr <= 0;
next_state <= s1;
end if;
when s1=>
ram_CS <= '0';
ram_OE <= '1';
ram_WE <= '0';
addr <= 1;
next_state <= s2;
end if;
when s2=>
ram_CS <= '0';
ram_OE <= '1';
ram_WE <= '0';
addr <= 2;
next_state <= s3;
end if;
when s3=>
ram_CS <= '0';
ram_OE <= '1';
ram_WE <= '0';
addr <= 3;
next_state <= s4;
end if;
when s4=>
ram_CS <= '0';
ram_OE <= '1';
ram_WE <= '0';
addr <= 4;
next_state <= s5;
end if;
when s5=>
ram_CS <= '0';
ram_OE <= '1';
ram_WE <= '0';
addr <= 5;
next_state <= s6;
end if;
when s6=>
ram_CS <= '0';
ram_OE <= '1';
ram_WE <= '0';
addr <= 6;
next_state <= s7;
end if;
when s7=>
ram_CS <= '0';
ram_OE <= '1';
ram_WE <= '0';
addr <= 7;
--next_state <= s0;
next_state <= s8;
cs <= '1';
cselect <= cs;
end if;
when s8 =>
-- if scl = 1 then
-- sda <= 0;
next_state <= s0;
end case;
end process com;
