Problem with flickering display (using PIC16F72 for a clock circuit )
sajeev
Kerala-India
Hi
I am using 16f72 for a clock circuit using 4 seven segment displays.
I have written the code in assemby.I used 32.768khz crystal with timer0 to generate 1 second delay.The problem is that,as the crystal frequency is this much low the display sometimes gives small flickering.I have written the same in C also.There result was not so good as the assembly code.How to solve thise problem.Its not possible for me to use any additional ICs for driving the segments..
Regards
Re: Display problem
Refresh @ 100Hz will give a flikker free display. so with 4 displays this means refresh every 2ms which is not a problem even at 32 KHz osc.
Re: Display problem
Hi
My project contains a keyboard,2 rotary switchs..
It reads time from the rotary switches for on/off of light.And keboard scanning is also there.My display routine here
segment_display MOVF temp0,W ; ROUTINE FOR DISPLAYING LEDS IN MULTIPLEXED MANNER
CALL pattern ; CALL THE PATTERN FOR THE DIGIT
MOVWF PORTC ; SEND THE PATTERN TO LEDS
MOVLW .31 ; ENABLE FIRST DISC
MOVWF PORTA
MOVF temp0,W
MOVWF PORTA
MOVLW 0xff
MOVWF PORTA
MOVF temp1,W
MOVLW .47 ; ENABLE SECOND DISC
MOVWF PORTA
MOVF temp1,W
MOVWF PORTA
MOVLW 0xff
MOVWF PORTA
MOVF temp2,W
MOVLW .55 ; ENABLE THIRD DISC
MOVWF PORTA
MOVF temp2,W
MOVWF PORTA
MOVLW 0xff
MOVWF PORTA
MOVF temp3,W
MOVLW .59 ; ENABLE FOURTH DISC
MOVWF PORTA
MOVF temp3,W
MOVWF PORTA
MOVLW 0xff
MOVWF PORTA
RETURN
I set a breakpoint at segment_display and the time to reach again at this point was 25ms.So what should i do?
Regards....
Re: Display problem
Hi My Friend
to be free of flikker you must refresh the display at a rate minmume 40Hz or say 50Hz for each segment then you have 4 seven segment then your minimum refresh rate must be 4X50=200 Hz or 5 msec which is 1/200
then the best way to do that is to configuar a timer INT with 5 msec to display every digit then you have a flikker free display
Regards
Re: Display problem
Hi
I was able to the display properly without using interrupt.Iam using timer0 interrupt in the program.So when interrupt occurs while the mc is in the display routine,the currently displaying segment is seems to be brighter for a short time.So when the interrupt occurs i blanked the segments.But i still can detect the difference in display during interrupt.Is there any other way to solve this?
Regards
