[General] Problem with Ds1307 RTC
pravin35
Newbie level 5
Newbie level 5
Pune/Coimbatore
hello everyone,
I bought a new DS1307 from the market including Crystal (32.76khz).
i connected ds1307 in bread board and given 5v when i tried to check the crystal frequency (Pin2) in Oscilloscope i couldn able to see 32.76khz i don know what's wrong with the circuit. i don think i made wrong circuit because its simple circuit have less connections:roll:
Anyone have faced this kind of problem with DS1307. need solution for this help me pls.....:cry:
Exactly what value do you read from your oscilloscope?? Its may be the tolerance of the crystal due to which there is a change in value ..
is the crystals body is grounded? may be it will help you.
do you checked the values from a microcontroller or any debuggers
if not do it and varify the RTC is working or not
hi ,
i got 50hz sine wave from the crystal 2 pin and know its not expected one... i don think its a because of crystal tolerance..
hi,
i dosent try with micro-controller i just connected RTC circuit in bread board and checked for crystal pin 2 it should generate 32.76khz rite?? how can i connect Ground for crystal body in bread board??? need to solder on crystal body???
hi ,
hi,
No, take a jumper above the crystal and attach the jumber to the body of cryster firmly
hi,
It doesn't work out!!!!!!!!! i am frustrated i don know whats the problem i have tried with 5 new crystals,.........
Any software configuration required for starting the clock in RTC..
i don think its a issue of hardware...
Now my rtc is working i didin do any thing just downloaded the sample code fron site and tried and its updating the RTC data and time.. and sending to comport..
but Still value in oscillator 2 is 50hz.... is it rite or wrong??? expected is 32.76khz
