problem with dcm_sp - doesn't recognize the change
mersault
Member level 2
chile
Hello
I have a problem with this item.
I put one in my design and i put some values for the clkdiv variable.
Then I chaged that value but ISE doesn't recognize the change, the clock is the same as the first time that I ran the program.
Is this a bug from ISE?
Do you have a solution?
Greetings
problem with dcm_sp
thank you for your answer, but that's not the problem..
in simulation works well..
but when i download the .bit file to the fpga, the system has the same frequency no matter how many times i changed the frequency in the schematic with the dcm
Re: problem with dcm_sp
Sorry,
DCM_SP has been plagued with problems through several versions of ISE.
What versions are you using, including service packs?
Are you using a Dev Board, if so what the model?
Have you checked out the other postings in this forum for DCM_SP?
I maybe able to recreate the problem here, I have several Dev boards and a couple of ISE versions.
