Problem with cypress microcontroller
alfadaco
Newbie level 3
does anybody know how to program this chip (CY7C63743C) from cypress, and if there is a cheap programmer compatible with this chip?
Thanks.
alfadaco
Newbie level 3
Are you sure, Keith? Because on cypress.com miniprog is not mentioned about programming CY7C63743C and even if miniprog is the correct programmer, I don't know how to connect it to the microcontroller...
Can you help me? Because on cypress.com it's not well explained...
Thanks.
keith1200rs
Super Moderator
Staff member
Yorkshire, UK
No, I am not sure. I haven't full access to information at the moment but I will try to find out later when I am back at my computer. And yes, Cypress's web site is cr@p.
Keith
alfadaco
Newbie level 3
Ok thanks Keith!!
You're right about cypress.com!!
I'll wait for your answer! :D
Alex
keith1200rs
Super Moderator
Staff member
Yorkshire, UK
alfadaco
Newbie level 3
They are too much expensive for me...
The miniprog would be a good compromise.
I'll try to ask Cypress's support directly and we'll see what they answer...
Thanks for you support!
Alex
keith1200rs
Super Moderator
Staff member
Yorkshire, UK
Also post on the psocdevelopers forum. I know the question has been asked on there before, but there are some good Cypress technical guys who hang out on there and you get through to the knowledgeable ones quicker than going through Cypress Tech support!
Keith.
N_Arm
Member level 1
keith1200rs
Super Moderator
Staff member
Yorkshire, UK
Best way is to download one of the many demo projects from the Cypress web site. If you buy one of their development/demo boards, that would be a good way to get started.
Keith.
N_Arm
Member level 1
Hi Keith,
We bought Cypress chip and programmer will it help me. If you know any links post it here...
keith1200rs
Super Moderator
Staff member
Yorkshire, UK
It depends which chip you have bought. Here are some: PSoC® 1 - PSoC - programmable embedded system - on - chip integrating configurable analog and digital peripheral functions - programmable - embedded control applications - mixed - signal controller functionality - Cypress Semiconductor
I used one of these first: CY3210 - PSoCEval1 - Cypress Semiconductor and if you look on that page there are loads of demo projects and application notes to go with it. You could use the demo projects from that board. Some are quite simple and that is always the best way to start.
Keith.
N_Arm
Member level 1
Thanks Keith and Anitha, your inputs are really worthy and helps me a lot.
