Dec 11, 2009 #1 P poluekt Full Member level 2 Joined Dec 11, 2009 Messages 130 Helped 45 Reputation 90 Reaction score 44 Trophy points 1,308 Location Russia Activity points 1,813 Code coverage ius82 Hello! I have a problem with running code coverage in ius82: ncelab: *F,COVSCNDRY: Coverage is not supported for designs compiled with the secondary compiler.. Click to expand... I use next ncelab coverage options: -coverage all -covdut dut_name
Dec 13, 2009 #2 A aji_vlsi Advanced Member level 2 Joined Sep 10, 2004 Messages 643 Helped 85 Reputation 170 Reaction score 12 Trophy points 1,298 Location Bangalore, India Activity points 4,944 Re: Code coverage ius82 poluekt said: Hello! I have a problem with running code coverage in ius82: ncelab: *F,COVSCNDRY: Coverage is not supported for designs compiled with the secondary compiler.. Click to expand... I use next ncelab coverage options: -coverage all -covdut dut_name Click to expand... Try: Code: nchelp ncelab COVSCNDRY My guess is you use svpp flow, but it is a wild guess. Look at irun flow or best is to ask CDN support Ajeetha, CVC www.cvcblr.com
Dec 14, 2009 #3 P poluekt Full Member level 2 Joined Dec 11, 2009 Messages 130 Helped 45 Reputation 90 Reaction score 44 Trophy points 1,308 Location Russia Activity points 1,813 I don't use svpp. Code: ncelab/COVSCNDRY = Either remove coverage options such as -COVERAGE or use the primary compiler. In what the difference between primary and secondary compiler? No this problem in ldv5.60.
Dec 30, 2009 #4 P poluekt Full Member level 2 Joined Dec 11, 2009 Messages 130 Helped 45 Reputation 90 Reaction score 44 Trophy points 1,308 Location Russia Activity points 1,813 Problem is closed. I used GCC_VERS=3.2.3. Code coverage works with GCC_VERS=4.1.
