Problem with Cadence IC5033 shortcuts
js0p
Junior Member level 1
cadence shortcuts
Hello everybody
I've just finished to install Cadence IC5033 on RHEL 3.0 AS and works fine. The only problem is that any shortcut is enabled. For example, if I use the Virtuoso schematic editor I cannot use shortcuts to add instances, move, delete, etc using only the keyboard. I have to use menus, with a lot a clicks...
I've been looking for any option to enable this shortcutsbut I didn't find it. Can anyone help me?
Thanks a lot. Any help is very much appreciated.
Best regards.
cadence shortcut
Type:
cp install_dir/tools/dfII/cdsuser/.cdsinit ~/
install_dir is your installation directory.
    js0p
keyboard shortcuts cadence
It works! Thanks a lot! :D
i'm having the same prob, cant use shortcuts.... i've installed in Cadence in CentOS. wen i type the command which u have given in the terminal, it shows an error asking for destination file. Pls help. I'm not very familiar with Linux.
hey, first of all great job on edaboard, thanks a lot for all your help guys!
I'm a cadence beginner and I'm working on a basic inverter for a start- my keyboard shortcuts aren't working either.
I tried copying the bindkeys.il file into my home directory, and common_bindkeys.il.. yet it doesnt work.. someone help me pls !
