problem while interfacing the ds1307 for EEPROM memory
anboli
Full Member level 2
Full Member level 2
i had interfaced the DS1307 for the EEPROM memory with 89s52,
im giving the direct value to the specified memory address and its no problem while writing, same way while reading also no problem,
but when im passing an argument to the specified memory address, and then i dono whether it write the same data or not and im reading the value from that address means i giving a wrong data.
and i having the doubt, whether we can pass argument?
i posted my program here, could you help me please?:-(
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
        #include <at89x52.h>
        #include "i2c_rtc.h"
        sbit str  = P3^0;
        sbit stp    = P3^1;
        sbit set    = P3^2;
        sbit up     = P3^3;
        sbit down   = P3^4;
        sbit ok     = P3^5;
        sbit buzzer = P1^5;
        unsigned char count, count1;
        void hex2dec_sc(unsigned int l);
        void hex2dec_mn(unsigned int k);
        void monitor();
        void sc_set();
        void delay();
        void start_count();
        void stop_count();
        void store_data();
        void stop_count_set();
        void write_init(int wr_value,wr_value1);
        void read_init();
        void write_run();
        void read_run();
             void delay(unsigned int count)
            int i,j;
            for(i=0;i<count;i++)                              //  100 ====> 1.5s && 1000 ====> 15s
            for(j=0;j<1275;j++);
                  int x,x1,x2;
                  x = k/10;             //quotient
                  x1 = k%10;            //remainder
                  x2 = x1<<4;
                  P0 = (x2|x);  //displaying the counting value in P0
                  int x,x1,x3;
                  x = l/10;             //quotient
                  x1 = l%10;            //remainder
                  x3 = x<<4;
                  P2 = (x3|x1);
                void start_count()
                    while(1)
                    monitor();
                    stop_count();
                    read_init();
                        if(count1==0xffff)
                        {  count1=59;
                            if(count==0)
                                count=10;
                                stop_count();
                        count = count-1;
                    count1= count1-1;
                    write_init(count,count1);
                    delay(130);
            void monitor()
             unsigned int set_data=00;
             if(set==0)
              while(1)
                 { hex2dec_mn(set_data);
                   if(up==0)
                     set_data = set_data+1;
                     if(set_data==60)set_data=0;
                     count = set_data;
                     hex2dec_mn(count);
                     delay(30);
                   if(down==0)
                     set_data = set_data-1;
                     if(set_data==0xffff)set_data=59;
                     count = set_data;
                     hex2dec_mn(count);
                     delay(30);
                   if(ok==0)
                   delay(100);
                   sc_set();
            void sc_set()
            { unsigned int set_data1=00;
                while(1)
                  hex2dec_sc(set_data1);
                       if(up==0)
                         set_data1 = set_data1+1;
                         if(set_data1==60)set_data1=0;
                         count1 = set_data1;
                         hex2dec_sc(count1);
                         delay(30);
                       if(down==0)
                         set_data1 = set_data1-1;
                         if(set_data1==0xffff)set_data1=59;
                         count1 = set_data1;
                         hex2dec_sc(count1);
                         delay(30);
                       if(ok==0)
                       hex2dec_mn(count);
                       hex2dec_sc(count1);
                       delay(20);
                       while(str==1);
                       start_count();
            void stop_count()
              if(stp==0)
                    while(str==1);
                    start_count();
            void write_init(unsigned char wr_value, wr_value1)      /// receiving the arguement
              start();
              send_byte(0xd0);
              aknowledge();
              send_byte(0x08);
              aknowledge();
              send_byte(wr_value);
              aknowledge();
              send_byte(wr_value1);
              aknowledge();
              stop();
            void read_init()
            {  unsigned char romvalue,romvalue1;
               start();
               send_byte(0xd0);
               aknowledge();
               send_byte(0x08);
               aknowledge();
               start();
               send_byte(0xd1);
               aknowledge();
               romvalue = read_byte();
               aknowledge();
               romvalue1 = read_byte();
               aknowledge();
               stop();
               count = romvalue;
               count1 = romvalue1;
               hex2dec_mn(count);
               hex2dec_sc(count1);
            void main()
             P0 = 0x00;
             P2 = 0x00;
             P3 = 0xff;
             str    =   1;
             stp    =   1;
             set    =   1;
             up     =   1;
             down   =   1;
             ok     =   1;
             buzzer = 0;
             count = 10;
             count1 = 45;
             write_init(count,count1);                         ////argument passing here
                 while(1)
                read_init();
                monitor();
                while(str==0)
                    start_count();
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
*******************************I2C program*********************************
    #include "intrins.h"
    sbit sda = P1^7;                                //sbit sda=P2^0;
    sbit scl = P1^6;                                //sbit scl=P2^1;
    bit ack;
    unsigned char reead,Day;
    void aknowledge()     //acknowledge condition
    scl=1;
    _nop_();
    _nop_();
    scl=0;
void start()        //start condition
    sda=1;
    scl=1;
    _nop_();         //No operation
    _nop_();
    sda=0;
    scl=0;
void stop()         //stop condition
    sda=0;
    scl=1;
    _nop_();
    _nop_();
    sda=1;
    scl=0;
void send_byte(unsigned char value) //send byte serially
    unsigned int i;
    unsigned char send;
    send=value;
    for(i=0;i<8;i++)
        sda=send/128;           //extracting MSB
        send=send<<1;           //shiftng left
        scl=1;
        _nop_();
        _nop_();
        scl=0;
   ack=sda;                 //reading acknowledge
   sda=0;
unsigned char read_byte()           //reading from EEPROM serially
    unsigned int i;
    sda=1;
    reead=0;
    for(i=0;i<8;i++)
        reead=reead<<1;
        scl=1;
        _nop_();
        _nop_();
        if(sda==1)
            reead++;
        scl=0;
    sda=0;
    return reead;               //Returns 8 bit data here
thanks for the reply,
i had interfaced the clock program already, but im trying to use the ds1307 as eeprom memory..
LaTeX Commands Quick-Menu:
