When I try to zoom in order to see the layers of the device ,I tried to increase stop in options > display but it shows me a box with a cross on it.your help appreciated
Those boxes with "X" fill are saying that it can't
find the contents.
Property-edit them, see what library it thinks it's
looking for, then check your library list (Library
Manager) and see whether the library is defined
and if so, that there's "stuff" under the directory
location
Yes, because you are trying to see "stuff that isn't there"
(or, stuff that isn't anywhere Cadence knows to look).
Do what I told you. Property-edit the "X" blocks, see
what they are and where their library directory is (or
is supposed to be).
Problems can also include a switch-view, stop-view
"misalignment" between what Cadence looks for, and
what the kit provides.
I tried to do what you have said, but I don't know exactly the properties to add, chould I modify cell properties or instance properties. Thank you for your help.
I have a warning in WIC of cadence when adding a pmos_vtl to my layout, it says that :
The Pcell super master: NCSU_TechLib_FreePDK45/pmos_vtl/layout is not a SKILL super master.
The usage of non-SKILL Pcells in Virtuoso is not a supported feature.
Is it a serious problem, because when I try to vieww deep layers of my instance by increasing the stop level I get a X fill, Can it be the source of the problem.Your help appreciated
When I try to zoom in order to see the layers of the device ,I tried to increase stop in options > display but it shows me a " X " fill. I tried to change properties, but I don't know exactly the properties to add, chould I modify cell properties or instance properties.
Also ,I have a warning in WIC of cadence when adding a pmos_vtl to my layout, it says that :
The usage of non-SKILL Pcells in Virtuoso is not a supported feature.your help appreciated
