Antonios
Banned
i add the properties that i need to transfer it to the allegro.cfg as flow
[ComponentInstanceProps]
PART_NUMBER=YES
SEWEDY_PART_NUMBER=YES
TOLERANCE=YES
VALUE=YES
ROOM=YES
VOLTAGE=YES
the pstxprt.dat extracted from netlist contain my properties as flow
PART_NAME
C10 'CAP NP_C0805':
VALUE='100nF',
TOLERANCE='10%';
SECTION_NUMBER 1
'@GHANA 1PH UI_4.CONTROLLER(SCH_1):LDO_REGULATOR@GHANA 1PH UI_4.LDO_REGULATOR(SCH_1):INS8548306@DISCRETE.CAP NP.NORMAL(CHIPS)':
C_PATH='@\ghana 1ph ui_4\.controller(sch_1):ldo_regulator@\ghana 1ph ui_4\.ldo_regulator(sch_1):ins8548306@discrete.\cap np.normal\(chips)',
VALUE='100nF',
PART_NUMBER='CS0008',
TOLERANCE='10%',
SEWEDY_PART_NUMBER='0805 - X7R - 10 - 100nF K 10%',
PRIM_FILE='.\pstchip.dat',
SECTION='';
but i can not access this properties from Allegro when i create Report
PART_NUMBER=YES
TOLERANCE=YES
VALUE=YES
ROOM=YES
VOLTAGE=YES
PART_NAME
C10 'CAP NP_C0805':
VALUE='100nF',
TOLERANCE='10%';
SECTION_NUMBER 1
VALUE='100nF',
TOLERANCE='10%',
SECTION='';
