lloydi12345
Member level 4
Good day, I'm not sure if the title is right.. I would like to ask for help because my PIC16F877A doesn't recognize the input voltage which is 3.9v and 0v from the comparator LM324's output voltage. I am using Port A as an input and test it if it's logic 1 or logic 0 then the motors will move. I used this code for my Edge Detector Mobot (based on the concept of line following mobot), here it is:
I hope you can help me :sad:
list p=16f877A ; list directive to define processor
#include <p16f877A.inc> ; processor specific variable definitions
__CONFIG _CP_OFF & _WDT_OFF & _BODEN_OFF & _PWRTE_ON & _XT_OSC & _WRT_OFF & _LVP_OFF & _CPD_OFF
CBLOCK 0x0c
FIRST
SECOND
THIRD
ENDC
ORG 0x000
goto main ; go to beginning of program
ORG 0x004
; isr code can go here
main
BANKSEL TRISA
MOVLW 0XFF
MOVWF TRISA
BANKSEL TRISB
MOVLW 0X00
MOVWF TRISB
BANKSEL PORTB
FORWARD:
MOVLW 0X01
MOVWF PORTB
call delay
BTFSS PORTA,0
GOTO LEFT_EDGE ;0XXX
GOTO LEFT_NO_EDGE ;1XXX
LEFT_EDGE: ;0XXX
BTFSS PORTA,1
GOTO BACKWARD ;00XX
GOTO TURN_RIGHT ;01XX
LEFT_NO_EDGE: ;1XXX
BTFSS PORTA,1
GOTO TURN_LEFT ;10XX
GOTO CHECK_OBSTACLES ;11XX
CHECK_OBSTACLES: ;11XX
BTFSS PORTA,2
GOTO LEFT_SENSOR_OFF ;110X
GOTO LEFT_SENSOR_ON ;111X
LEFT_SENSOR_OFF:
BTFSS PORTA,3
GOTO FORWARD ;1100
GOTO TURN_LEFT ;1101
LEFT_SENSOR_ON:
BTFSS PORTA,3
GOTO TURN_RIGHT ;1110
GOTO BACKWARD ;1111
TURN_LEFT:
MOVLW B'00000101'
MOVWF PORTB
call delay
call delay
call delay
call delay
call delay
GOTO FORWARD
TURN_RIGHT:
MOVLW B'00001001'
MOVWF PORTB
call delay
call delay
call delay
call delay
call delay
GOTO FORWARD
BACKWARD:
MOVLW B'00000110'
MOVWF PORTB
call delay
call delay
call delay
call delay
call delay
GOTO TURN_RIGHT
delay ; 1 second delay
MOVLW .150
MOVWF THIRD
LOOP_1_SEC:
MOVLW .255
MOVWF SECOND
LOOP_125_MS:
MOVLW .255
MOVWF FIRST
LOOP_.5_MS:
NOP
DECFSZ FIRST, F
GOTO LOOP_.5_MS
DECFSZ SECOND, F
GOTO LOOP_125_MS
DECFSZ THIRD, F
GOTO LOOP_1_SEC
return
END ; directive 'end of program'
