Problem on cover of tracker
RajivConfident
Member level 3
Member level 3
Pokhara,NEPAL
I am working on the project of senser which is used to determine the temperature of the object in the refrigerator.So i need the cover of that senser.Which object is much favorable for that purpose(cover of sensor)?
A cover over the sensor? Is it attached to an object, and you wish to insulate it from the refrigerator's air?
Does the sensor send a wireless signal? Then a cover made of metal might interfere.
Cut a dome-shaped piece from a soft plastic bottle. Glue it over the sensor. Etc.
