May 16, 2007 #1 Q quan228228 Full Member level 4 Joined Mar 23, 2006 Messages 196 Helped 16 Reputation 32 Reaction score 3 Trophy points 1,298 Activity points 2,571 change_names Before we write out netlist, we should change the name of objects. In names rules, i use command 'change_name -rules verilog -hier'. could u tell me what is 'verilog ' in command'? i never define name rule as verilog. But this command work well. Txk! quan228228
May 16, 2007 #2 N nanda_kishore Member level 1 Joined Mar 8, 2007 Messages 34 Helped 7 Reputation 14 Reaction score 0 Trophy points 1,286 Activity points 1,562 dc_shell change_names It is asking to change the names acoording to the rules and syntax of verilog HDL language.. so that the resultant file can be diectly treated as verilog file and proceed with it.
May 17, 2007 #3 D drizzle Member level 3 Joined Jun 7, 2006 Messages 56 Helped 2 Reputation 4 Reaction score 0 Trophy points 1,286 Activity points 1,667 change_names syntax "verilog" is default name rules defined in DC u can use report_name_rules to see what is the concrete content. u can also define the name rules by yourself and change the name in the command. drizzle
May 18, 2007 #4 Q quan228228 Full Member level 4 Joined Mar 23, 2006 Messages 196 Helped 16 Reputation 32 Reaction score 3 Trophy points 1,298 Activity points 2,571 change_names & dc i understand and found the default name rules file ".dc_name_rules" in synopsys install direcoty 'syn/admin/setup/'. Thanks for your help. quan228228
