Jing
Junior Member level 1
I used Dracula to run DRC. The resolution and grid value defined in Dracula rule file is 1nm. I had no DRC errors. But someone used Calibre to check DRC and got large number of errors, which is offgrid. They said that the correct manufacturing grid is 10nm. The only way to get rid of this error is to redraw the whole layout? That would be extremely troublesome, because my chip is very very big. Is there any other easy way to fix this problem?
Added after 2 minutes:
when i draw the layout, i set the grid value to 1nm. that is why there is offgrid error if the grid value change to 10nm when checking the drc
