Problem interfacing LPC2148 with GSM
Twisted_transistor
Member level 1
Hi.. I've written the following code for sending an SMS via the GSM module..
The code runs fine i.e. the entire code executes when the GSM is not connected to the LPC2148 board. This I can tell because I've inserted statements in the code to light LEDs so that I know till where the code has executed.
But, however, when I connect the GSM module to the board, code execution stops at the point indicated in the following code. It does not proceed further.
I've tried and tried but really cannot figure out why this is happening. Someone pls shed some light on this mystery. This is an important part of my college project.
#include "LPC214x.h"
void init(void);
extern unsigned char at[]="AT";
extern unsigned char cmgf[]="AT+CMGF=1";	                        //Text format in GSM modem
extern unsigned char cmgs[]="AT+CMGS=\"+91##########\"";           	//Mobile number to which the msg is sent
extern unsigned char msg[]="dips";
void senduart1(unsigned char a)					//sends a byte through U1
U1THR=a;
while(U1LSR!=0x60);
void sendstring(unsigned char *p)			 //Sends a string of data through UART1
while(1)
if(*p=='\0') break;
senduart1(*p++);
void delaygsm()							  //delay function
int i,c=0;
for(i=0;i<4000000;i++)
c++;
int main()
PINSEL0=0x00050005;			//initialized U0 and U1 as UART and not GPIO
PINSEL1 = 0x00000000;
PINSEL2 = 0x00000000;
IO1DIR = 0xFFFFFFFF;
IO1SET = 0x000F0000;
delaygsm();
delaygsm();
delaygsm();
delaygsm();
IO1CLR = 0x000F0000;
init();
sendstring(at);
senduart1(0x0D);							// equivalent of
senduart1(0x0A);							//	 enter key
delaygsm();
delaygsm();
delaygsm();
delaygsm();
IO1SET = 0x00010000;                        //Code execution stops here wen GSM is connected- does not proceed further
sendstring(cmgf);
senduart1(0x0D);
senduart1(0x0A);
delaygsm();
delaygsm();
delaygsm();
delaygsm();
IO1SET = 0x00040000;
sendstring(cmgs);
senduart1(0x0D);
senduart1(0x0A);
delaygsm();
delaygsm();
delaygsm();
delaygsm();
sendstring(msg);
senduart1(0x1A);
delaygsm();
delaygsm();
delaygsm();
delaygsm();
IO1SET = 0x00080000;
senduart1(0x1A);
IO1CLR=	0x000F0000;
void init()
U1LCR=0x83; //8-N-1, enable divisors
U1DLL=0x62; //9600 baud (9615)
U1DLM=0x00;
U1LCR=0x03; //8-N-1, disable divisors
U1FCR=0x07;
hey.. thanks.. The problem was that I was not handling the interrupts caused by the GSM module..
Do you know how to handle the interrupts?
It would really be helpful..
use the following code
#include<lpc214x.h>
#include"Config.h"
#define SW1 (IO0PIN & 0x00001000)
#define SW2 (IO0PIN & 0x00002000)
#define SW3 (IO0PIN & 0x00008000) //Macro Functions to read Push button switches on LPC2148 dev. board
#define SW4 (IO0PIN & 0x40000000)
void enter(void);
void GSM_init(void) ;
void send_sms1(void);
void send_sms2(void);
void send_sms3(void);
void send_sms4(void);
#define BUZZER_ON() IO0CLR=(1<<11) //Macro Functions to turn ON Buzzer
#define BUZZER_OFF() IO0SET=(1<<11) //Macro Functions to turn OFF Buzzer
int main()
PINSEL0 = 0x00050005; // Enable UART0 and UART1 Rx and Tx pins
IODIR0= (1<<11) ;
IODIR0=(0<<12)|(0<<13)|(0<<15)|(0<<30);
BUZZER_OFF();
lcd_init();
UART1_init();
GSM_init();
lcd_cmd(0x80);
lcd_string("OBJECT IDENTIFICATION");
lcd_cmd(0xC0);
lcd_string("USING RF COMMUNI.");
Delay(400);
while(1)
if(!SW1 && SW2 && SW3 && SW4)
BUZZER_ON();
Delay(60);
BUZZER_OFF();
lcd_cmd(0x01);
lcd_cmd(0x80);
lcd_string(" OBJECT ONE ");
send_sms1();
Delay(400);
if(SW1 && !SW2 && SW3 && SW4)
BUZZER_ON();
Delay(60);
BUZZER_OFF();
lcd_cmd(0x01);
lcd_cmd(0x80);
lcd_string(" OBJECT TWO ");
send_sms2();
Delay(400);
if(SW1 && SW2 && !SW3 && SW4)
BUZZER_ON();
Delay(60);
BUZZER_OFF();
lcd_cmd(0x01);
lcd_cmd(0x80);
lcd_string(" OBJECT THREE ");
send_sms3();
Delay(400);
if(SW1 && SW2 && SW3 && !SW4)
BUZZER_ON();
Delay(60);
BUZZER_OFF();
lcd_cmd(0x01);
lcd_cmd(0x80);
lcd_string(" OBJECT FOUR ");
send_sms4();
Delay(400);
void GSM_init()
u1_print("AT");
enter();
Delay(10);
u1_print( "ATE0");
enter();
Delay(10);
u1_print("AT+CMGF=1");
enter();
Delay(10);
void enter()
u1_byte(0x0D);
u1_byte(0x0A);
void send_sms1()
u1_print("AT+CMGS=\"09214659486\"");
enter();
u1_print("Object One Detected");
u1_byte(0x1A);
lcd_cmd(0x01);
lcd_string("MSG SENT");
Delay(200);
void send_sms2()
enter();
u1_print("Second Object Detected");
u1_byte(0x1A);
lcd_cmd(0x01);
Delay(200);
void send_sms3()
u1_print("AT+CMGS=\"9036005512\"");
enter();
u1_print("Third Object Detected");
u1_byte(0x1A);
lcd_cmd(0x01);
Delay(200);
void send_sms4()
enter();
u1_print("Fourth Object Detected");
u1_byte(0x1A);
lcd_cmd(0x01);
Delay(200);
